MetalMan
MetalMan's Avatar
02.29.2008, 04:10 PM
Originally Posted by drkros3 View Post
well i just looked and the warehouse has tons of them so we might be getting some in on wed.
Our store got them either last Wednesday or last Friday (a week to a week and a half ago). I'm sure it helps that we're right next to the warehouse, though.
Rich, how is the stock servo holding up for you? Your Rage has a lot more power than mine did when one of the servo gears stripped. Also, how are the temps on your Mamba 25 with that heatsink?
Last night I drove around my Rage with the KMS 2213 3200kv outrunner (about 28mm outer diameter and 25mm length) on the stock battery and with the Mamba 25. I had to change some settings around on the Mamba 25 to get it to run well, but then I ran into a problem - the stock battery can't dish out the power required by both a Hitec 225MG servo and the outrunner motor (even though it was only geared for ~20mph). Tonight I will see what my 3s Lipo options are from what's available at Hobby People, but I'm guessing there won't be much.
