Patrick
Patrick's Avatar
03.01.2008, 12:26 AM
What's the pitch of the gears your using, and what tooth counts?
I used a 1515 f on the stock mount, but only with mod 1 gears.
I think the C50 hackers are a similar diameter, and lots have guys have used those at racing over the last 4 or 5 years, they just had to use the 72t 32p spurs.
Are you trying to get the motor closer to the transmission or further away? I don't think grinding the lower hole will let you go any closer, and if you trying to get further away, I'd adjust the top slot.
