03.01.2008, 07:18 PM
Originally Posted by jadesportster View Post
I'm running the stock stampede vxl pinion and spur. I think it's 48p and the spur is 86t. I'm going to go to robinson racing's website to see if they've got the correct spur and pinion I need. any suggestions on sizes?
My pinion must be shot because i keep tearing up spurs (2 per afternoon-6-7 battery cycles)
If you use a 58t jato spur, then a 13t 32pitch pinion gear (traxxas or robinson) will work fine, and maintain the same ratio as the stock pinion/spur.
