coolhandcountry
coolhandcountry's Avatar
09.04.2005, 12:58 PM
Did have to glue nothing with beadlocks. had to put a good amount of blue on with regular rims. I only glued one side at a time. I find that when you do both you seem to pull the bead loose as the glue is drying. Just a suggestion. The bead locks are a little heavier. Not sure how weight concerned you are. You have a piece of aluminum on the out side of the proline commando series. They seem to be pretty touch. I ran the stock plastic hexes on my 7xl. they did not hold up. Just thought I would point out some problems I had when I went to power over Novak.
Peace!
Country
Help support the
Rc-Monster
Buy here
