ziggy12345
03.02.2008, 04:26 AM
Originally Posted by Countryhick View Post
I was using the available space under the top plate, extending out toward the body. Do you have a photo of your 835 with the cells in it?
I just want to reiterate that I need to be able to RACE continuously for 15 mins (10 mins. minimum) I'm not interested in just doing speed runs.
I have also found out that a high performance nitro engine out of a 1/8 can produce nearly 3HP. Is 2237.0996 Watts out of the question? Of course this would not be continuous.
A .21 circuit engine produces around 1.8 HP regardless of what it says on the box and thats at a very limited rev range. The torque f the motor is almost non existant. It would be comparable to a 1hp electric motor.
Cheers
