03.02.2008, 02:18 PM
If you are planning on using a torsen diff; you need at least a center and a front one. Only a center torsen won't help much or gets too much load. The thing is that if one front wheel is lifted, in a corner, all the energy goes to that wheel, causing a rather high difference in rpm of both outputs of the diff.
I would consider getting the xray diffs instead. They will increase their torsen effect with more power applied.
