03.03.2008, 01:00 PM
Most of your motor speeds are between 5k and 9k rpm, too slow. Optimum motor speed for a feigao xl is around 35k rpm.
Best thing to do is to take the kv of the motor and divide it into 35000, that will give you the total voltage. Take that number and divide it by 3.7 (1 cell lipo nominal voltage) and that will give you the number of cells.
So:
6xl :2779kv = 3s (4s is too high, over 40k rpm)
7xl :2382kv = 4s = 35253 rpm
8xl :2084kv = 4s = 30843 rpm or 5s = 38554 rpm(5s is over 35k rpm, but it works fine)
9xl :1853kv = 5s = 34280 rpm
10xl :1668kv = 5s = 31228 rpm or 6s = 37473 rpm (depends if you round up or down)
11xl :1516kv = 6s = 33655 rpm
12xl :1390kv = 7s = 36001 rpm
So we see that some motors are good for a certain cell count, while others (8xl, 10xl) are good for two different cell counts. Spinning the motors between 35k and 40k rpm is acceptable, as long as you are gearing for around 40mph, or have a very light vehicle. If you try to gear up you may have heat issue with these motors, as they are less effecient. My specs are for something like a revo or a truggy that is not super heavy.
Now, I will await the comments that a 7xl is too hot to run 4s lipo. I have a feeling this is due to the fact that it can pull some serious juice on 4s and really good batteries are required to keep up, or else everything heats up. Don't get me wrong, it will get warm, and be gearing sensitive, but what feigao is not like that? Maxamps are not going to keep up, trust me I know. Trakpower/flightpower, neuenergy or kokam are going to be required to run this.
You can spin the higher quality motors (neu, leher, hacker c50) faster and gear down lower, which produces more torque via gearing. This also amplifies the benifit of switching to a better built, more effecient motor. Lower gearing and higher motor speeds are much more responsive than the opposite.
I have recently tested a hyper buggy on 4s lipo with a hacker c50 8l motor (3300kv). Motor speed is 48840rpm , but the motor stay cool, as gearing is 12/46. Top speed is near 45mph, I have an 11t pinion on order to drop the speed and pick up some runtime. That said I still got 25mins or runtime from a 4900 mah 25c battery. This buggy is not very light, but has tons of power!
