03.03.2008, 01:14 PM
Now the kb should be more powerful than the feigao. However, it uses a 6mm shaft and 30mm bolt pattern for m4 thread screws. That means that it will not bolt up to the motor mount, or use std pinions.
Main problem is the larger diameter, which will most likely cause the battery not to fit in the chassis. I was going to use a kb xl in my savage and then found the motor issue with the batteries. Now I am using an aveox 1300kv motor on 8s lipo. Same diameter as a feigao xl, so my batterys will fit.
