PowerRocks
03.04.2008, 12:23 AM
Good suggestion, I think someone else hacked one of these up to use in a Jato.
I think at work in the metal shop we have pieces of 1/4" aluminum or stainless steel off cuts (scrap metal). I'll make a drawing in cad when I have time at work, and get the punch operator to bend me 2 sets of mounts which I will have to drill and cut. I'll get two L pieces cut and bent. One will have a shorter base than the other. I'll use the shorter base to support the motor body. Thus I will have to punch a hole in it to the exact size of the motor. The longer piece is where the front of the motor will bolt up to. The piece with the shorter base placed on top of the longer piece, they will be bolted to the chasis. I will try to use the original nitro motor mount.
