03.04.2008, 01:50 AM
If you go with losi, look at the aftershock, especially if you plan on converting it. amainhobbies has it for 309$ and they always have 25$ off coupons.
The aftershock is nearly the same as the lst2, and with the upgrade kit 100-120$, you can basically make it into a lst2, only with plastic shocks instead of aluminum. You can then spend the 300$ you save on other upgrades, or your electric conversion.
Worth taking a look.
