MetalMan
MetalMan's Avatar
03.05.2008, 09:00 PM
Originally Posted by skellyo View Post
I've been reading over this and hope you guys can answer a few questions for me.
Is the spur in this metric 48P like the MQ?
What Lipos fit the stock location? I noticed you mention the Dualsky lipos...are these the same 1700's that fit the MQ/Detta?
Is the stock servo a mini servo?
Sorry for the questions, but it's not like there's a ton of info on these from what I've seen. I may be interested in picking one up to bash with, but want to make sure I know how big my budget needs to be before I do so.
48p metric spur, mine now has a Robinson 22t 48p metric pinion on it.
The battery tray will fit packs that are maybe 1/8" wider than what the RC18T can fit, but about 1/2" shorter. Mine has an Impulse 3s 1330mah pack that fits perfectly aside from being about 3/8" shorter than the battery tray.
The servo is something like a mini, I think its about the size of a Hitec 85. I have found that a Hitec 225MG fits with the removal of some small ribs on the chassis, and cutting the tabs off from the servo.
