lutach
lutach's Avatar
03.08.2008, 03:02 PM
Can you explain exactly what settings you used lutach? I'm sure I can figure it out, but why "re-invent the wheel"?
To enter program mode in the HV110 I left the setting on my radio as is (TH Trim 50/50). After programming was done, I set the trim to -100 and the sub trim to max for brake. You will have to make little adjustments to match the throttle so when you give some throttle it will not have a long neutral range. Just have 2 model open on your radio. One for running the vehicle and one for programming the controller. Make sure brake is disabled on your ESC.
