david lamontagn
03.09.2008, 01:05 AM
Yea. I have been running 5s on my MMs for quite a while now. Never had an issue except for early when we were just figuring out that the MM didn't like the Neu. I toasted a MM, but I think that it would have happened even if I wasn't running 5s, it was mostly due to MM/Neu cogging issues IMO. With 2 pole motors the MM has run 5s all day long for me.
Yea, CEN finally smartened up and made the cross-pins stock, but that was after I bought mine and had already done the aftermarket cross pin mod from Gene Hickerson.
Thanks for the props on the conversion.
But tell me, if you download the new version on the castle web site, is you can run 5s with the Neu motor without any chance to toast it????
Because lot of guys here said that the new version run very well with the Neu motor.
