glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.09.2008, 03:46 PM
I have barely done anything with the new firmware, but I noticed it is a lot noisier than before at startup/crawling speeds with my 1512.
The screeching you have may just be "normal"... maybe it's just worse with the novak motor?
Edit: You said it no longer cogs... but the thread title makes it sound like it is. It makes a bad noise, but does it take off smooth and strong or does it cog?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
