orangecrush
03.09.2008, 09:00 PM
Originally Posted by hobbimaster View Post
So what are considered weak lipo's? I run 2 orion 4800's which are rated at 15c, or 74 amps. I have yet to experience these cut-out issues on lipo mode. I have it set to reduce RPM, 4s.
THough I'd have to look at my setup again, I don't think it was "reduce RPM" setting that caused the problem. It's when the setting is set to cut off.
I had my 5S set to cut off and had the same problem. Changed the setting to reduce rpm and it runs fine.
I was up till 3am last night replacing every Traxxas TRX end with a Dean's end. Now that it's done, I'll install the 5S low voltage detector that I bought from Mike.
Mark
