Thread: Home Audio
03.10.2008, 05:35 PM
So, you and linc are converting GTPs too? Seems like I was just about the only one and now you're the third that I remember seeing in a short while. FYI: Mike just put up the GTP motor mount in the store...
Interesting that mike now has a motor mount, pity that I cannot use it as I will be using a kb45 10l in my gtp. Actually it is a mbx buggy that has had a variety of powertrains that I am converting to the gtp. Basically the same thing, plus I will use the single spur solid center drive from the dirt oval gtp, with a plastic 51t ofna spur. Power will be from a pair of 2s2p milwaukee cells (thanks Briang!) in series thru a MM. Should be good for 40mph or so and will be lots of fun. Plus the buggy is well used, so I will not mind beating it up. I will post a few pics when I finish it up this week.
