03.11.2008, 02:43 PM
I used a hardened pin, most likely one of the tamiya wheel pins. Held it in place with a grub screw from a pinion (set screw). A hardened roll pin would work too. Only issue would be to get it back out after the pin is pressed in. I hope it holds up!
