Sneeck
RC-Monster Custom
Sneeck's Avatar
09.06.2005, 10:39 AM
You mean only use the shock mount of the g3 suspension while using some other kind of suspension?
You can use it, only I think you need to add a little shim inside the shock(between the body and piston) to lower it enough. Fuel line does the trick.
  Send a message via MSN to Sneeck
