Thread: Svh
03.12.2008, 08:58 PM
Phoenix-SHV (F310C) 1.00 Brake Ramp Immediate After full off throttle is applied and the controller has waited the specified Brake Delay, the brake will immediately be set to the desired brake strength.
Phoenix-SHV (F310C) 1.00 Brake Ramp Very Fast After full off throttle is applied and the controller has waited the specified Brake Delay, the brake will ramp from 0% brake to your specified brake strength very quickly (Ramp takes .1 seconds if your desired brake strength is 100%)
Phoenix-SHV (F310C) 1.00 Brake Ramp Fast After full off throttle is applied and the controller has waited the specified Brake Delay, the brake will ramp from 0% brake to your specified brake strength quickly. (Ramp takes .27 seconds if your desired brake strength is 100%)
Phoenix-SHV (F310C) 1.00 Brake Ramp Medium After full off throttle is applied and the controller has waited the specified Brake Delay, the brake will ramp from 0% brake to your specified brake strength in a medium amount of time. (Ramp takes .51 seconds if your desired brake strength is 100%)
Phoenix-SHV (F310C) 1.00 Brake Ramp Slow After full off throttle is applied and the controller has waited the specified Brake Delay, the brake will ramp from 0% brake to your specified brake strength slowly (Ramp takes 1 seconds if your desired brake strength is 100%)
Phoenix-SHV (F310C) 1.00 Brake Ramp Very Slow After full off throttle is applied and the controller has waited the specified Brake Delay, the brake will ramp from 0% brake to your specified brake strength very slowly (Ramp takes 1.7 seconds if your desired brake strength is 100%)
Phoenix-SHV (F310C) 1.00 Brake Ramp Super Slow After full off throttle is applied and the controller has waited the specified Brake Delay, the brake will ramp from 0% brake to your specified brake strength super slowly (Ramp takes 2.6 seconds if your desired brake strength is 100%)
Phoenix-SHV (F310C) 1.00 Cutoff Voltage Auto Li-Po Use this for all applications where you are using Lipo batteries. When selected, the controller will detect the number of Lithium Polymer cells in series in your battery pack, and set the cut off voltage to 3 volts per cell. When you plug the battery pack into the controller, after the initialization tones the controller will flash and beep the number cells it counted, so you can confirm the controller setting. If the cell count is incorrect, make sure your batteries are charged and the correct cell count is flashed BEFORE flying. Note: Do not use Auto Lipo with NiMH or NiCad cells.
Phoenix-SHV (F310C) 1.00 Cutoff Voltage 36.0V Use when running a 12 cell LiPo battery pack.
Phoenix-SHV (F310C) 1.00 Cutoff Voltage 42.0V Use when running a 14 cell LiPo battery pack.
Phoenix-SHV (F310C) 1.00 Cutoff Voltage 48.0V Use when running a 16 cell LiPo battery pack.
Phoenix-SHV (F310C) 1.00 Cutoff Voltage 54.0V Use when running a 18 cell LiPo battery pack.
Phoenix-SHV (F310C) 1.00 Cutoff Voltage 60.0V Use when running a 20 cell LiPo battery pack.[/
