03.14.2008, 09:46 AM
It depends. Does the balancing charger hook up like a hyperion balancer? Does it have certain adapters that hook up to the battery tap and then plug into the charger, or do the actual battery taps plug into the charger?
You wiill have to make a charge harness. I made one to charge a pair of trakpower packs in series (4s) to hook up to my lba balancer. I can make you one too, if you like.
