03.14.2008, 03:42 PM
I just quickly read through that post - I guess I did miss it.
If both ESCs burned the same way, I would take a good look at everything before hooking up another ESC of any kind.
Are any motor wires touching (or have any exposed areas that could touch?
Is your wiring correct? I assume you are running dual 2s packs and each is hooked seperately to the ESC?
