Hydrodancer
Hydrodancer's Avatar
03.14.2008, 10:05 PM
It sounds to me like the oil your running is too thick. The rear is getting full power and is causing your front end to lift and unload. If you thin out the oil the front wheel will stay more planted and pull the buggy through corners.
The only other options are to lighten up on the lead finger or move/add weight to the front to keep it down.
