03.16.2008, 09:00 PM
I do not have any s can motors at the moment. The vxl rotor is the same length as a s can. The windings are shorter to allow the solder plate to be fitted. This may cause the motor to produce less power than the feigao, much like the cc motors do (they have less wire and shorter rotors).
Now this will really add some fuel to the fire. A sv27 motor is the same length as a feigao s can, has 6 poles and a 5mm shaft. It can pull an emaxx to 35mph. It can also pull a 4wd smaller vehicle like a crt.5, or a Ls10 to 40mph or more. Now in a pede on 4s it would easily be capable of waxing the velineon motor. It has tons of torque. I may have to throw it in my vxl pede roller that I just acquired and see how it does!
