crazyjr
crazyjr's Avatar
09.07.2005, 10:04 AM
Hey Mothman. If you have a computer based radio (JR Futaba Airtronics ect) see if you can use the third channel with the throttle so you can set the throttle at zero brake and full throttle then set the third channel at full brake and zero throttle on the brake servo so you never have to worry about accidently hitting reverse. you may have to use reverse when programing but you can dial it out when done.
