mriccucci
mriccucci's Avatar
03.20.2008, 11:19 PM
I think the timing was set to 10 when i looked at the mamba. Ill deffinatly turn the punch control on and see if that helps. It seemed to lurch and be jittery.
don't worry about the flat spot, I have never had a pinion slip off of the shaft due to the lack of a flat.
I see that now that i have had the pinion mounted and then taken it off.
One other major area of concern is getting the transmission to stay in gear. Unfourtenly i dont have the OEM linkage peice for the servo so i cant even stick it in there. I thought of getting the single speed but for bashing i dont see the need for the 74 dollars and that little weight. Any suggestions on this?
Thanks agian for all the help guys!
