lutach
lutach's Avatar
03.23.2008, 03:42 PM
Originally Posted by DrKnow65 View Post
luatch, would you be stuck with outrunners for that high of a voltage (thinking less than 600kv with 74 volts) ? or are there inrunners that go that low?
Here are some choices so far:
Neu Motors
1527/3D 770Kv (Will be almost at the RPM limit)
1527/3.5D 660Kv
1527/2Y 625Kv
1527/2.5Y 500Kv
1527/3Y 420Kv
1521/2Y 780Kv (Will be almost at the RPM limit)
1521/2.5Y 630Kv
1521/3Y 525Kv
1515/3Y 725Kv (Will be almost at the RPM limit)
Mega Motors
ACn22/50/3 710Kv
ACn22/45/3E 800Kv
Lehner
30xx
Kv from 404 to 808
2280
Kv from 411 to 822
1950
Kv from 418 to 836
Plettenberg
Bolido
HP 370/50/A1 S
HP 370/40/A2 Heli
HP 300/40/A3 Heli
The right motor will depend on the SHV controller. I will try to keep the RPMs between 30000 (For normal running) to 60000 (For speed runs).
