VintageMA
VintageMA's Avatar
03.24.2008, 09:33 PM
Another question - what are your MM settings for the following:
Punch Control
Motor Timing
Startup Power?
I've had several conversation with the Castle guys on the phone and the "Normal" setting for Timing is like a 10% advance on timing. They recommend setting the following:
Timing - Lowest
Start Power - Low
Punch Control - up to the batteries you are using. If you have punch control set at 0, try kickng it up to 30% and adjust it from there.
“Everyone has a right to be stupid; some people just abuse the privilege.”
