Countryhick
03.27.2008, 02:39 AM
The HRS mode is usefull only if you run digital servos
If you use normal servos, donK't use HRS mode or you'll smoke your servos.
And if you have digital servo, you can run in PPM mode and all will be fine with the MGM
Thanks David. Is there anyone that can confirm the new firmware works with HRS?
Regards Andrew
