03.27.2008, 05:18 PM
Not sure about the email address, but have you tried to center your throttle trim and set your forward and reverse EPA to 100%? If you can, set the EPA to as high as it can go. It sounds like the ESC is not seeing the required ~2ms pulses for max throttle to enter programming mode.
Something else to check out: The button on one of my Quarks is not quite in the exact proper position for effective pressing. I had to use a hex wrench tip to get it to press. Or, you could pop off the top plastic plate (don't slide it off!) to get to the button. I assume you've read the manual...
