03.27.2008, 09:03 PM
Take a close look at your rear diff, where the rear center drive shaft connect on the rear diff. You have the outdrive how slide on the rear diff input pinion shaft. This outdrive is secure with a little allen screw. This allen screw must be tighten up with good locktite on it.
