jhautz
jhautz's Avatar
04.01.2008, 01:27 AM
Try this... I was talking to Mike about this and he mentioned that it worked for him, but I dont have a new MM to try it with. Mine are all the older ones.
plug the MM into the usb and from the computer choose the option to resore or reset the factory settings. The unplug it from the usb and plug it in to the battery. It should work on 5s, but there is not LVC set yet. Once you have gotten it to turn on, shut it all down again and then plug it back into the usb and program it with the computer to have a 15v cut off voltage. then try it again. He said that it worked for him and his will run on 5s now. I have been wanting someone to try it, cuz if it works I will probably buy another MM, but I only want one if it will work on 5s.
If you can test this and see if it works I would apreciate it.
to make it...
or break it...
Silent...But Deadly
