Duster_360
04.01.2008, 08:34 PM
I have an RD logic trans case for a Tmaxx (currently on a SM). There were probs - the hole for the brake puck (little brass thing that pushes the inner brake plate) was not deep enough - not even close. Its hard to make it deeper without a milling machine and a flat bottom mill, but between deepening the hole and reducing th thickness of puck, it allows good brakes. Took time and needed a lot of had fitting.
The other prob was in shimming the trans shafts. The brg to brg inside distance in the RD Logics case must be larger than stock cause I had to use a lot more shims than a stock plastic case to cut the travel. If you get one, be prepared to do some work to make it work right.
It is a nice looking case though with a brushed alum finish versus the usual bright and shiny finish on others.
