Thread: new big motor
MetalMan
MetalMan's Avatar
09.11.2005, 01:31 AM
I'll bet it uses 4-5mm mounting screws. Those wires in the back that switch the winding configuration-they switch between wye and delta. The wye should have more torque and be more efficient.
EDIT:
You can get 8mm pinion gears at http://www.sdp-si.com
I picked out a nice mod0.5, 8mm bore, 20t gear:
https://sdp-si.com/eStore/PartDetail...32&GroupID=591
