fore106
04.04.2008, 05:32 PM
Well the rain finally stopped. (I installed the tekno wing while I was waiting)
I loaded up the batteries....12 cells 4300mah......and fires it up. Ran for about 10 minutes with no problems. Speed probably around high 20's low 30's. hits second gear a little late but i can adjust that. front wheels came up for a few feet if I gave it full throttle off the line. All and all im very pleased. I didnt check the temps while I was running but nothing was too hot to touch. I did check temps when I got inside......motor and esc were around 100 and the batteries were 150.
Now I will play with gearing...maybe lock into second gear. I also have two 7 cell packs I may try but im not sure if 16.8v is too much.
I cant wait for the 4s 8000 lipo to get here.
Where should I wire the fan into?
