04.06.2008, 12:10 AM
Originally Posted by big greg View Post
not if you run them in series, mm will not take 5s let alone 6s, if you run them in parrallel for 3s 16000 mah it will work but the 7xl doesny really do well on 3s
Not really, the 7xl will turn a bit slow on 3s, but depending on gearing it will work. 35mph may be the most before the load on the motor pulls too much thru the esc. The xl motors have power, but tall gearing will overheat the esc, and most likely the motor.
