04.07.2008, 12:26 AM
Didn't the brake kit come with the correct hex? Looks good Linc. The mount should do the trick as long as it doesn't allow too much flex. I assume the motor sits on the bottom plate so it should be plenty strong enough. I'm surprised there aren't more mounts like that mount too but mikes revo mount is fairly similar.
Nope, but the hex that the ss kit looks good, and I think the lhs has one in stock.
The motor does sit on the mount, and I plan to put a rcm heatsink on there too, so there should not be much flex. Maybe I should make some more, or get the local machinist to turn out a few. Mine is a bit rough for resale, but a nicely macined one would be good. For the best gearing options it has to be as thin as possible, to keep it close to the stock motor mount plate.
