wade7575
04.08.2008, 11:19 PM
I think I will upgrade right away so I will not need to worry about bending anything.The reason I would rather get it now is because I do not have a LHS and it sucks waiting for part and I see the parts are in stock right now.I also seen on towerhobbies if you enter part # rrp1212 robinson is making a 12 32 pitch 5MM bore and they also have a 13 and 14 tooth pinion as well with 5MM bores you just have to change the last 2 to a 3 or 4.The guy at Novak said a lot of E-MAXX owners are bending the stock shafts because of so much extra Torque is being sent out the stock pinion shaft,he told me they were going to release 4.5 and 6.5 versions with the 5MM already installed as stock hardware witch will be nice to see.Thanks for all your help and man you do not know how happy I found a 12 13 and 14 tooth pinion in 32 pitch with a 5MM bore.
