wade7575
04.08.2008, 11:25 PM
There is one other thing I was wondering I see alot of guys that first got the 4.5 and 6.5 setups that the pinion hangs 2 or 3MM over the end of the shaft so you can line the pinion up gear up with the spur will this matter I myself can not see it matter.I have seen a few guys run the pinion offset a little bit but olny by 5 to 8 thousands of an inch in some pictures.
