GO-RIDE.com
04.10.2008, 01:36 PM
Cemetary Gates,
What springs are you running on the ofna front buggy shocks?
On the front with the Jato pink 1.4 springs I'm pretty much have max preload, which really isn't much because the Revo shocks are not threaded very far. I was thinking of going up to the 1.6 springs. How are the green 1.1 springs setting up?
One other thing I noticed is that if you tighten the bottom cap tight on the revo shocks it creates a lot of drag btwn the shock shaft and seal. I'm thinking of puting a small oring or thin nylon washer btwn the cap and shock body so the cap stays tight but doesn't over preload the seal.
E-8ight - Tekin RX8 2000kv/4S
