Gustav
Gustav's Avatar
09.11.2005, 10:19 PM
I think they're actually the same kv though.Serum said something about some companies measuring kv by using the motor as a dynamo and measuring the rpms needed to produce 1 volt,wheras the wanderers may be measured under load.It's not a big difference anyway even if the method is the same,a low kv gives you less current draw and better runtimes(i think).
