Thread: ESC Blues
jhautz
jhautz's Avatar
04.10.2008, 09:44 PM
I have a MM with a full 5s pack problem like that. It runs on 5s well except for if the pack is totally topped off. I actually found that my solution was to set my charger to 4.15v/cell rather than 4.2v and it works with no issue. If I have a fully charged pack I just hold the truggy in the air and let then motor run for a minute or so. Somtimes it take shutting the MM switch off and on again and running it untill it quits, then doing it again untill it stays running. Kind of a pain, but then it runs fine after the peak is taken off the pack. Its wierd, I have 3 MMs running 5s and only one of them is that way. The other 2 run 5s fine with no problems.
That was the only solution I found. If you find another solution let me know Id love to find it also.
Mine doesnt have any cogging or heat issues like yours though.
to make it...
or break it...
Silent...But Deadly
