kingiggy262
BL-Revo
04.11.2008, 01:02 AM
Originally Posted by Revracer View Post
so does anyone know when this thign will really be out? i got a brushless revo sitting here waiting for a good esc. im about to just get a mamba max since i am only running 3s... but it is on a 6pole...
Just to let you know the MM and the MMM will be using the same firmware v1.17 so if you are only using 3s and don't need to pull 110+ amps then the MM will work just as well on your 6 pole motor as the MMM because the firmware is not different.
