Thread: cc bec question
sikeston34m
sikeston34m's Avatar
04.11.2008, 06:11 PM
It's pretty much plug and play on any voltage inside it's acceptable limits for input voltage.
The programming is there to adjust it's output voltage. I believe factory default is to output 5.0 volts.
If you want to "turn it up" to 6.0 volts, let's say, then you will have to program it to do that.
I hope this helps.
