trani repaired!
plettenbergs
plettenbergs's Avatar
trani repaired! - 04.12.2008, 11:26 AM
....no damage...the small hollow pins that hold the drive gears to the shaft sheared off!...thank goodness i also located the two small pieces inside the trani case...they were stuck to the sides...in tact and not smooshed flat by runing through the gears!...i will be switching to lipo this week before i blow out something big$$$!...i can shave almost 2 pounds right there,if it still is too heavy i will drop a motor!
I am sure i can find a new ride for a BIGmaxximum and a Schulze 18.97!
i still need an exact part number for the exact LIPO batts to purchase,please?
i will be gettind the Hyperion duo charger!
