04.12.2008, 01:55 PM
Bear in mind over-all voltage too. The MM esc can only run 12~14 cells maximum, so if you have 2x 6 cell packs, and a ~2000kv motor, your only real option is to run the packs in series. You could ofcourse run them in parallel, but you would only get half the speed, if that, but double the runtime...
