azjc
04.12.2008, 03:46 PM
Originally Posted by DwightSchrute View Post
I was geared 66 spur/40t pinion...i went to 76/30....
I looked up some info on the capacitors, and it said to solder them between the 2 power wires....there was a place for the pic, but it had been long since removed.
do those novak capacitors get soldered between the 2 wires from the esc that plug into the battery?
can i solder them to the wire and not the board?
I have VXL Rustler that I have a MM, 4 cell 5000 lipo, and 54/15 gearing, running the CC BEC and the Battery and ESC barely gets warm, and the Feigao 9L gets between warm and hot, and I dont run a fan or extra caps...I would shoot for about a 3.5-1 gear ratio and with the 4 cell and stock VXL motor your getting over 50,000 rpms I would say that is beyond its max
