lutach
lutach's Avatar
04.12.2008, 06:21 PM
Originally Posted by jzemaxx View Post
I have silicone tubing on all 4 shocks already and also a custom wheelie bar. The wind is what is taking the truck....its all of a sudden to. Also its not consistent. Usually around 65-70mph range the truck begins to sway the rear end side to side as lift is created on the rear of the body, then past that it will sometimes just take off....like an airplane with wings. I'm working on reducing frontal area as much as possible and lift. Also I am working on making some bolt on difusers for the rear of the chassis. The MMT is the perfect chassis for high speed runs since its a flat panel. All the other big trucks have an open chassis underneath which creates alot of lift. Also the longer the wheelbase the better I have been with holding the truck down.
Do you have tubing inside the front shocks under the piston? I will start doing speed runs again soon and I have my truck sitting a bit lower on the front and I know it will create much more down force, but I know it will stay on the ground. I also have a wheelie bar, but I think it won't be needed. I sure hope Mike can do my chassis soon. With the design I have done, I can use 44.4v and 74v with those long packs from Kong Power, Flight Power and Thunder Power.
