BOOGIE444
04.16.2008, 11:20 AM
Originally Posted by Vrooom666 View Post
is there any how to guide to lock the 2 speed gearbox on my savage ?
Its been a while sence I have locked mine in second but I will do my best....
Basically go through the manual on how to adjust the shift point, and the screw that you adjust for a earlier or later shift, screw it in the direction ( screwing it out ) for a early shift. Basically screw it out as far as possible without it falling out or rubbing on something, then put a whole crap load of loctite or ca glue on the screw so it holds its setting.
Now your tranny is locked in second, you still need mechanical brakes if you are running a brushless conversion because there is a one way bearing in the tranny so your esc brakes will do nothing to stop the truck when applied.
BTW, locking your tranny in second gear makes the tranny 136.77% stronger lol. Basically almost all the time when someone breaks their savage tranny gears is because of the sudden slam when it shifts from 1st to 2nd.
