azjc
04.16.2008, 11:55 AM
Originally Posted by abiye View Post
for my money the hitec 5955TG is the best i think... 333oz and .15 speed... and most of all it has a brass bushing embedded in the top servo case to prevent the pin that the gears ride on from wearing the case... in my experience that is the reason why servos fail, the case wears and the gears don't mesh as tight as they used to and they strip...
as long as you have a servo with at least 200on/in you will be fine, the different companies all rate their servos differently, I have the Hitech 5955 and I am very pleased with the results, it does make the humm sound that the JR doesnt, it bothers some people...I guess you could wear earplugs when running your truck if it bothers you that much...
