Diffs
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Diffs - 04.17.2008, 05:45 AM
I can only guess that if I suspected some kind of problems with one of the diffs, first off I would disconect the center dogbone and check for any resistance in the diff movement. If that is good, then you may have a problem with somthing else. If it does not feel right, then remove the diff open it up and inspect it.
